EVGA 闭锁 CPU 散热器 (CLC) 120/240/280/360
液态散热极致表现
EVGA(CLC) 120/240/280/360液态CPU散热器正式上市. EVGA 新的液态冷却器提供你意想不到的性能表现、低噪音、人性化软体监控以及RGB变色控制.
为高效能而生
全新散热块提供进阶的风流及表面积传热效能,完全让你耳目一新的冷却效能表现
与您的
EVGA GeForce GTX
显卡同步*
连接您的显卡与EVGA CLC 散热器,透过软体同步RGB LED颜色,一键控制RGB LED,并贴心的帮你纪录颜色
* 可在特定显卡上使用
套管
从散热器到散热块的全套管
全新 EVGA 风扇
新风扇为更高规格的散热及低噪音而生。流线造型外壳降低噪音水平,独特的叶片设计提供无人能敌的冷却性能。 Teflon Nano 轴承延长使用寿命
EVGA 风流控制
软体
EVGA 软体让您轻松控制 EVGA CLC 液态散热器,包含风扇速度、曲线、RGB 灯、套管控制、纪录资料….等众多功能。所以,如果你记不起来之前设定,没关系 ! 系统会帮你自动记录
可调式
水流 及 风扇 速度
可自订水流及风扇速度,让系统保持于最佳状态及最安静的运作
400-HY-CL36-V1
Features
- Built in 360mm radiator and 3x 120mm fans help dissipate the heat keeping the CPU as cool as possible. Fan can also be swapped or customized.
- Teflon Nano Bearing in the fans reduce noise and increase lifespan, while the curved housing improves air flow through the radiator to limit vibration and noise.
- Variable controlled fans allow dynamic fan speed based on CPU temperature, and the water cooling efficiency means the fans can operate at a lower speed to reduce noise.
Specs
Waterblock
- Premium Retention parts for Intel LGA2066/2011/2011-v3/1150/1151/1155/1156/1366
- AMD retention ring for supporting AM2/AM3/AM4/FM1/FM2/TR4
- 100% Copper
- Fully controllable RGB LED
- Noise Level = 20dB(A) (MAX)
Radiator
- 396mm X 122mm X 28mm (LxWxH) (without Fans)
- 396mm X 122mm X 53mm (LxWxH) (with Fans Installed)
- Aluminum
Fan
- Size: 120 x 120 x 25mm (x3)
- Speed = 500-2400RPM
- Airflow = 74.82 CFM (MAX)
- Static Pressure = 4.04 mmAq (MAX)
- Noise Level = 16.0 dB(A) (MIN) – 39.9 dB(A) (MAX)
- Lifespan = 80,000 Hours
Warranty
- 5-Year Limited Warranty
400-HY-CL28-V1
特色
- Built in 280mm radiator and 2x 140mm fans help dissipate the heat keeping the CPU as cool as possible. Fan can also be swapped or customized.
规格
水冷块
- 为Intel LGA2066/2011/2011-v3/1150/1151/1155/1156/1366以及未来产品保留优质部分
- AMD保留环能支援AM2/AM3/AM4/FM1/FM2/TR4及未来产品
- 100%铜制
- RGB LED 控制
- 噪音值 = 20dB(A) (最大值)
散热器
- 312mm X 139mm X 27mm (长x宽x高)
- 铝
风扇
- 尺寸: 140 x 140 x 25mm (x2)
- Teflon Nano 轴承
- 速度 = 600-2200RPM
- 空气流动 = 113.50 CFM (最大值)
- 静压力 = 4.20 mmAq (最大值)
- 噪音等级 = 16.0 dB(A) (MIN) – 39.5 dB(A) (最大值)
- 寿命= 80,000 小时
保固期限
- 五年保固年限
400-HY-CL24-V1
特色
- Built in 240mm radiator and 2x 120mm fans help dissipate the heat keeping the CPU as cool as possible. Fan can also be swapped or customized.
规格
水冷块
- 100%铜制
- RGB LED 控制
散热器
- 276mm X 122mm X 28mm (长x宽x高)
- 铝
风扇
- 尺寸: 120 x 120 x 25mm (x2)
- Teflon Nano 轴承
- 速度 = 500-2400RPM
- 空气流动 = 74.82 CFM (最大值)
- 静压力 = 4.04 mmAq (最大值)
- 噪音等级 = 16.0 dB(A) (MIN) – 39.9 dB(A) (最大值)
保固期限
- 五年保固年限
400-HY-CL12-V1
特色
- Built in 120mm radiator and 120mm fan helps dissipate the heat keeping the GPU as cool as possible. Fan can also be swapped or customized.
- Teflon Nano Bearing in the fan reduces noise and increase lifespan, while the curved housing improves air flow through the radiator to limit vibration and noise.
- Variable controlled fan allow dynamic fan speed based on CPU temperature, and the water cooling efficiency means the fans can operate at a lower speed to reduce noise.
规格
水冷块
- 100%铜制
- RGB LED 控制
散热器
- 156mm X 122mm X 28mm (长x宽x高)
- 铝
风扇
- Teflon Nano 轴承
- 速度 = 500-2400RPM
保固期限
- 五年保固年限
