EVGA XR1 实况撷取盒,拥有4K Pass-Through及4K/60FPS 游玩时1080P/60FPS录影功能,即时与世界分享您的最新战况。 XR1同时搭载了进阶Pass Through模式,您仅需轻触按钮即可调整至144Hz FPS HDR。即刻甩开插拔线材的恶梦,XR1将成为简洁高效的实况帮手。
为游戏实况量身订做
即时撷取并直播您大获全胜的时刻:
商务人士的最佳伙伴
连接摄影机并以更画质开使您至关重要的的视讯会议、讲座及研讨会。:
满足重度直播一切需求
多组XR1及摄影机串接,实现多角度专业直播
自订义ARGB LEDs
按下中央按钮即可显示音量、更换颜色。:
内建混音功能
不必再跳出游戏调整,即可以中央按钮控制您的麦克风输入音量。
随插即「玩」
连接 XR1 即可透过OBS™开始直播,无须另外安装驱动程式。
EVGA XR1 RGB 软体
EVGA XR1 Video
“Thanks to the EVGA XR1, I’m able to deliver high quality video with clear audio on my livestream. It allows me to go full HD with 60FPS playback.”
- DJ Z-Trip
https://www.twitch.tv/djztrip
“My DJ Stream on Twitch focuses on high end graphics effects with multiple camera angles, and the EVGA XR1 was able to deliver full HD with 60 frames per second!”
- DJ Buck Rodgers
https://www.twitch.tv/djbuckrodgers
“I have been using EVGA products for years and now with the new XR1 my live streams are looking better than ever, and installation was a snap.”
- Arabian Prince
“The EVGA XR1 Capture Device has secretly been in use on our weekly streams for weeks without hiccups. We are using multiple EVGA XR1’s to bring in multiple camera angles, PC’s and more. Delivering full 1080P 60FPS gaming and video, and being Certified for OBS allows quick and easy installation!”
- EVGA Weekly
https://www.evga.com/evgaweekly/
141-U1-CB10-LR
- Interface: USB 3.0 Type-C
- Video Input Interface: HDMI 2.0 (up to 4K@60fps)
- Audio Input Interface: HDMI
- Video Bypass: HDMI (up to 4K@60fps)
- Video Resolution Input: 480p / 576p / 720p / 1080p / 1440p / 2160p@60fps
- Video Resolution Pass Through: 480p / 576p / 720p / 1080p / 2160p@60fps
- Video Resolution Advanced Pass Through: 720p / 1080p / 1440p@120fps
- Encode Resolution: Up to 1080p @ 60fps
- Encode Format: RAW
- Dimension: 130mm x 86.4mm x 32.95mm w/ Control Dial /130mm x 86.4mm x 24.15mm w/o Control Dial
- Weight: 159g
- 1080p@60fps Video Capture
- 1440p@120fps HDR Advanced Pass Through
- 4K@60fps Pass Through
- Built in Audio Mixer via Control Dial
- Certified for OBS™
